Gearing
Ok so the stock gearing sucks! My buddies are crushing me at the track on their 600's. Anyone have any suggestions on what gearing to do so that I can smoke these fools? Any input is appreciated! Thanks!
Guest
Posts: n/a
if you add more teeth to the back it will be easier for the small sprocket to move the rear sprocket. Stunt bikes gear down 2 in the front and add 1-9 in the back, the only disadvantage in this is your bike will run a hell of a lot louder cruising down the highway. I would leave the small sprocket the same and add 1-4 on the rear sprocket that should help.
