Flywheel Tuning for CBR600RR 07
Hello everyone,
I currently have a CBR 600 RR 07 (same engine as the current model) and I want to tune the flight wheel. I did some research on the web but I was not able to find any solutions.
Can you suggest any companies or shops that can help?
What modifications you would do?
My best regards
My best regards
wtf does that have to with anything? You could also attach a rocket to your bike, goto NASA, whats the point though, if factory teams aren't doing it except in world classes, then why does any unknown need it? There are a lot better mods to do for the money that will have a significantly larger gain in performance for significantly less money.
PS- to the OG, bikes don't have flywheels the same way a car does, some have balancers and some are balanced by a large piece that also transmits power to the gears of the gearbox, if you could somehow pull this off (the crank is one piece) and replace it with aluminum you would no doubt eat all the teeth of, and gain very little in lost reciprocating weight as it's such a small piece, and also have to have the entire motor built to match.
