Dyno Jet power commander ignition module
Old 08-22-2009, 12:45 AM
philthethrillohio's Avatar
Default Dyno Jet power commander ignition module
has anyone installed this? ive been reading up a little bit on it but want to here it from the horses mouth
Old 08-22-2009, 07:33 PM
flicbr929's Avatar
Its plug and play, but I would get a pro-tune with it. Do you have a full system exhaust? what year is your 600?
Also Check out the rapid bike by dimsport its the latest ECU and is much more adjustable and you can have more then 1 map.
http://web.dimsport.com/rapidbike/fi...rapidbike.php#
Old 08-23-2009, 07:58 PM
i have a 06 with K@n and a hotbodies shorty , i will be getting headers soon. i have power commander and had it prof tuned 107 to the wheel. what kind of gains are we talking with and with out full system with the timing box?
Old 01-10-2010, 02:31 PM
RedEIKO0713's Avatar
hotbodies will not make power, if you want real power you need a akra/arrow/leo/ or arata. the pc3 is an awesome device and the ignition module is decent, can add a little in spots, don't believe the claims of 5-7hp, i would guess maybe 2-3 in some spots, esp up top. DO NOT get the quickshifter with it, not worth the money to do what you can do with your right hand unless you are professionally drag racing. Got all 3 for my rr7 and will get a pc and igm on every bike from now on, not the qs though...
Old 01-12-2010, 02:22 PM
i did see gains with my hot bodies shorty. not big but def got 4 horse. i have had it tuned twice. im sure though i could get better numbers with a dif muffler. i know hotbodies is not the best but i love how its hidden under my tail. you no any other mufflers that i could replace my hotboides shorty with and still keepmy undertail? i just love how itis so slick looking
Old 01-12-2010, 02:43 PM
letsride's Avatar
You can save alot of money,if you can find a pcIIIr.It can adjust your timing up to 6*.
Old 01-13-2010, 09:31 AM
with an igm you should be able to adjust "timing" 10degrees either way
Old 01-13-2010, 11:02 AM
i have a pcIII its for a 06 do they make a r model ?
Old 01-14-2010, 10:45 AM
I remember hearing about the "r" pciii but haven;t heard about it for awhile... and dynojet's site doesn't list it.... ? the "r" i think was mainly used for cruisers... it's been awhile since i've heard about em though! dynojet's site also doesn't list the original pciii so maybe they're obsolete? you can only buy the pciiiusb or the pc5. it looks like you stuck with the pciiiusb if you have an 06', i've heard you prob can fit a pc5 on 07-08 but dynojet won't confirm. the pciiiusb is what i'm using although theres no need to get the igm unless you have a built motor or are running race gas.
Old 01-14-2010, 12:14 PM
letsride's Avatar
Yes the pcIIIr has been discontinued for some time that's why I said if you can find one.The r is for racing.Wish dynojet still made it.
Quick Reply: Dyno Jet power commander ignition module
