Comp Werkes Integrated tail light
Old Apr 27, 2007 | 02:19 PM
06RRRider's Avatar
Default Comp Werkes Integrated tail light
I just got my new tail light with the integrated turn signals and tried to install it, it worked briefley, just the brake light, no signals. Now I have a brake light that wont illuminate when I hit the brakes and no turn signals...I used the signal reducers and everything, anyone have any idea what I did? Did I blow a fuse somewhere? Any help would be much appreciated as I ride my bike everywhere cuz its my only transportation, thanks.
Old Apr 27, 2007 | 02:35 PM
dragonium25's Avatar
Default RE: Comp Werkes Integrated tail light
Check your fuses and wiring.
Old Apr 30, 2007 | 03:27 PM
pattersonc's Avatar
yo man,
I had the same problem and it was very frustrating. The problem is there isnt enough load for the LED lights to work properly. I tried the resistors and that didnt work either. If you get a signal that uses a buld (comp werkes makes one for the 600rr, but different system) if you put more load on the system it will work. Mine still blinks fast but they work. Also, my system isnt the integrated tail light, it is the other system with seperate bulbs. Hope it helps.
Fireplay5
Nov 15, 2007 04:18 PM
djhh212
Dec 26, 2006 09:46 AM
C17Crewchief
Nov 21, 2006 05:31 PM
UFsurfer
Aug 4, 2006 12:14 AM
kiggy74
Jul 4, 2006 08:33 PM
