Comp Werkes Integrated tail light
I just got my new tail light with the integrated turn signals and tried to install it, it worked briefley, just the brake light, no signals. Now I have a brake light that wont illuminate when I hit the brakes and no turn signals...I used the signal reducers and everything, anyone have any idea what I did? Did I blow a fuse somewhere? Any help would be much appreciated as I ride my bike everywhere cuz its my only transportation, thanks.
RE: Comp Werkes Integrated tail light
yo man,
I had the same problem and it was very frustrating. The problem is there isnt enough load for the LED lights to work properly. I tried the resistors and that didnt work either. If you get a signal that uses a buld (comp werkes makes one for the 600rr, but different system) if you put more load on the system it will work. Mine still blinks fast but they work. Also, my system isnt the integrated tail light, it is the other system with seperate bulbs. Hope it helps.
