Can't get it up!!!!
Old Feb 9, 2006 | 07:26 PM
FordFrenzy97's Avatar
Default Can't get it up!!!!
I want to make my bike easier to wheelie. I'm 5'11" 216 and I want to go with new sprockets. Will -1 +2 be enough to power up or should I go more? A friend of mine went -1 +6 on his 03 or 04 ninja 636. I don't know if the stock gears are the same as my 600rr but that sounds like a lot.
Old Feb 9, 2006 | 07:37 PM
Tahoe SC's Avatar
Default RE: Can't get it up!!!!
stock is already enough to power it up...i think you should get your timing down better.
-1 will do it for you...-1 +2 will come up real easy...poor RR...make sure you take her to the track and not all this wheelie stuff which she was not made for!
Old Feb 9, 2006 | 07:53 PM
Don't get me wrong, just want to wheelie every once in a while and I would love to go to the track but don't think there are any tracks around the bay area in FL.
Old Feb 9, 2006 | 08:04 PM
L8X's Avatar
L8X
heehee, heehee! ok, im being immature.
Old Feb 9, 2006 | 10:41 PM
05Tribal's Avatar
I you want it to wheelie "easier" and still want to ride it on the freeway then go with -1/+2. If you want to ride it to your local deserted business park parking lot to stunt ride, getting there only on city street and not going over 45 - 50mph then go up to what ever you want on the back.
Old Feb 10, 2006 | 01:00 PM
rubberband man's Avatar
Can someone explain what -1 +2 means as far as sprockets... i am a little uneducated when it comes to suspension.... thanks
Old Feb 10, 2006 | 03:02 PM
CMHGUY's Avatar
Might need to see a doctor for the "blue pill" LOL LOL [sm=groupwave.gif]
Old Feb 10, 2006 | 03:18 PM
Tahoe SC's Avatar
ORIGINAL: rubberband man
wow...not just in suspension i guess...buahhaha...it's the sprockets...to get quicker acceleration, you would either get a sprocket with less teeth up front or more teeth in the rear.
so -1 +2 means dropping by 1 tooth in the front and increasing by 2 teeth in the rear sprocket. so it's all gearing...and nothing to do with suspension.
get it? got it? good!
Old Feb 10, 2006 | 03:19 PM
Tahoe SC's Avatar
ORIGINAL: FordFrenzy97
there isn't much...you're pretty screwed...buhahaha j/k...you have to ride out of the state to hit some real nice roads...i'm very sorry...i will ride for you!
Old Feb 10, 2006 | 08:28 PM
cjbettis's Avatar
-1 in front is equal to about +3 in the rear....I did what are are thinking about but just went -2 up front...only $22 and a 15 min mod beginning to end. That way if going to do a track day can throw stock gearing back on...I have a -1 also just depending what riding going to do....the -2 is HUGE....not only for 'getting it up"...but also just acceleration off the line....I thought I needed a 1000RR until did this....going up in the back has bennefits but couldn't change around gearing all the time and a LOT more cost involved.
I went PBI sprockets through dealer.
