which cams to get?
Old Dec 14, 2007 | 08:11 PM
keithacole's Avatar
Default which cams to get?
ape racing for my f2
parrt# lift duration price
WH176 .308" .250° $565
no data for exhaust side
CBR6-201 .332" .239° $555
exhaust .308" .228°
CBR6-202 .352" .243° $340
exhaust .308" .228°
right away i know i have to call them about part #WH176 and the exhaust side, i got that from the website
the data on the 201-202 parts i got from a local shop, but the book they got it out of said it was from APE also, now when i bought cams for my car, i bought what everyone else had, it made my car faster, so i dont really know all the math that goes into cams, i just know what happens when you go too agressive, so the ones that are listed above are specified as direct drop-ins, no need for high compression pistons, or valve springs
why are the -202 so much cheaper then the 201?
my goal is to be able to keep up with newer bikes on the track, so im not worried about top speed
EDIT: i will be using a dyno to check overall gains, and i want to do it right.. also considering timing advancement
Old Dec 15, 2007 | 07:57 PM
Jason748's Avatar
Default RE: which cams to get?
All of APE's cams are from Web Cam Inc. They take stock cams, weld them up and re-grind them.
Here's the website with the actaul specs: WEB CAM INC F2-F3 CAM specs
While the cams will help, they're not going to give you the same power as a 600RR without additional motor work... milled head, Setting the cam timing, porting, valves, correct jetting, etc... and by the time you do all that you could afford a newer bike and them some.
Are you looking to "keep up" with newer bikes, or are you really looking to keep up with better riders on the track? Becuase the bike doesn't make the rider, the rider makes the bike. If you really want to be faster, take a few racing schools (not an intro to the track school, but a real racing school) You'll drop you lap times by much larger chunks of times than any bolt-on ever will.
Old Dec 16, 2007 | 10:16 AM
keithacole's Avatar
any idea which cams will yeild the most HP/Torque gain?
Old Dec 16, 2007 | 11:53 AM
Jason748's Avatar
ORIGINAL: keithacole
Where do you want to make your HP & TQ? Lower, Mid range, or up top in the RPM range?
Also is your bike a 49 state bike or a Calif bike?
I would call WEB CAM and talk to them as they will be able to tell you.
Old Dec 25, 2007 | 12:34 AM
sickz's Avatar
cams aren't for stock motors. they are not bolt on power.. cams are just a compliment tonumerous other modifications/machining
it's like a 3" exhaust on a n/a motor for a car... pointless unless u have a turbo.. thus cams are pointless unless u have higher cr, port work, etc.
Old Dec 26, 2007 | 09:59 AM
keithacole's Avatar
not exactly.
there are cams that are "bolt on" power, when manufactures produce an engine they dont have power as the #1 factor on there list, most of the time its "fuel consumption and emissions" so if you start changning out parts that go against this then you tend to cheat a little more power out of your motor
in your example you used a 3" exhaust on a n/a motor. your right you will probably lose power in that scenario, because of the loss of backpressure the volicity the exhaust gas travel is slower, but if your car had a stock 1" pipe on there and you changed it out for a 2" pipe you may increase power by letting the engine breath better
i swapped out the cams in my last car, had to bump up the fuel pressure, and along with my other mods i already had.. it was a direct bolt-on horse power increase.
now if there is anyone else that can give me a dyno chart of anyone of these cams vs stock cams along with the rest of there setup.. i would greatly appreciate it, until then i will be doing more research on how cams work, and the specs on our stock cams to see what will suite me more
Old Dec 26, 2007 | 11:50 AM
baxsom's Avatar
not exactly.
you are partially right. it is not the loss of backpressure that causes the gas velocity to slow down it is the fact that the gas expands so much sideways as straight that it is coming from the exhaust manifold faster than it can get out of the tail pipe.
ideally no backpressure is perfect but finding the balance gas velocity and pipe size is difficult.
that is why pipes tend to gradually get smaller as they leave the engine. the venturi effect causes the gas to speed up. yes it causes back pressure as a side effect but in the perfect size pipe, the gas would be leaving just as fast as it comes in. i posted up like 15 resources once on why no backpressure is ideal but yet people still hold to that old theory that back pressure is good.
Old Dec 26, 2007 | 12:34 PM
keithacole's Avatar
excellent peice of info
/me googles "define:venturi effect"
http://www.google.com/search?hl=en&s...mp;btnG=Search
Old Dec 29, 2007 | 09:39 AM
sickz's Avatar
that proves my point.. you had to do additional tuning.. not to mention you already had other mods before u installed the cams..
swappin' in cams into a completely stock bike will see a loss of power...
either way cams are pretty pointless on a bike that isn't raced religiously. you're better off gettin' a slipper clutch.
Old Dec 29, 2007 | 10:15 AM
keithacole's Avatar
ORIGINAL: sickz
did you ever read the original question? how are you helping me decide what cams to get?
thanks for your attempts to help
