the brake system
Old Nov 6, 2008 | 01:59 PM
07white600rr's Avatar
Default the brake system
so i did a search and really didnt find anythin that answers my question. my question is what is the best way to upgrade my brake system. i do street riding and a lil stunting, i do not go to the track and race. so what would be the best way to upgrade my brakes a lil and also add a lil style?
Old Nov 6, 2008 | 02:01 PM
be vertical's Avatar
Default RE: the brake system
Shortly Levers, Stainless or Kevlar lines, and better pads. You dont need to get into the master cylinders, calipers, and rotors unless your super hardcore and have money to spend.
Old Nov 6, 2008 | 03:20 PM
asidari's Avatar
galfer makes good products. from lines and pads to rotors. might want to check them out.
Old Nov 6, 2008 | 11:23 PM
tomp's Avatar
ORIGINAL: be vertical
+1, I'd also do rotors though.
Old Nov 7, 2008 | 07:26 AM
thanks for the advice. ya im staying away from the MC i hate having to bleed the systems and check for a while to make sure theres not air in the lines pain in the arss.
willlevers will really help that much?
Old Nov 7, 2008 | 01:43 PM
asidari's Avatar
i have pazzo levers. they have 6 different adjustments for clutch and brake. that way you can get your clutching and breaking the way you want.
Old Nov 7, 2008 | 03:48 PM
well whats the diff between those adjustments and the ones that come stock? is it a finer adj or wut?
Old Nov 7, 2008 | 09:09 PM
asidari's Avatar
yeah you can adjust them with a single finger. if you want to see pics of them ill get some up for you
Old Nov 7, 2008 | 11:47 PM
that would be great man if you dont mind doing that that is would help out alot
Old Nov 8, 2008 | 02:17 PM
asidari's Avatar
Here you go. If you need anymore let me know. i can take more.
