600RR engine in sidecar
Old Jun 27, 2007 | 01:55 AM
ringnalda's Avatar
Default 600RR engine in sidecar
I am putting a 600RR engine in a sidecar outfit for next year's isle of Man TT. Apparently the Motec computer is a good way to set up the engine ECU optimally, but is there another (better) way to go for mapping and optimizing performance without sacrificing reliability? This engine will need to run the 37 Mile circuit about 40% of the time at full throttle. Three times per race... And there are two races! Any help/suggestions much appreciated; I'm new at this.
Jan
Old Jul 1, 2007 | 12:18 AM
65ShelbyClone's Avatar
Default RE: 600RR engine in sidecar
That depends on what modifications you have made to the engine. If it is stock, then a proper tune will deliver the same reliability as a stock 600RR. If the engine is not stock, then dyno tuning will be the best method for creating optimal fuel and ignition maps.
Old Jul 1, 2007 | 08:39 AM
ringnalda's Avatar
The engine will be stock, but the exhaust and inlets will be different to the normal bike config. But how do I program the ECU, or which computer is the best to use to change the performance curves?
Jan
Bordo
Dec 29, 2013 07:00 AM
NINE2NINE
Jan 23, 2006 02:20 PM
