-   600 Modifications (https://cbrforum.com/forum/600-modifications-41/)
-   -   -1 front help (https://cbrforum.com/forum/600-modifications-41/1-front-help-39641/)
larry600 May 20, 2007 12:09 PM
-1 front help
i'm going to go with a -1 front my ? is did anyone just use the stock chain with all the links and if you did is there room for chain adjustment. i heard the -1 front lets the rear wheel go back a little farther.
greyd May 20, 2007 12:50 PM
RE: -1 front help
Works fine with stock chain unless old and stretched out. There was enough play on mine when I converted.
Tahoe SC May 21, 2007 06:08 PM
RE: -1 front help
it'll fit fine and you'll be able to adjust it fine. the wear indicator won't be accurate but you'll know when you need a new chain if it's kinking or you find yourself adjusting for the right tension every week.
