What performance mods should I do?
I just purchased a 2007 CBR1000RR.After I break it in, I plan to mod it (pc3, slip on, filter). WhatHP gains can I expectvs full exhaust? What do you guys recommend?
RE: What performance mods should I do?
you can mod it the day you bring it home.
you must first realize that with a slip on or full system you need to have a custom map done on it to get the most amount of performance as possible. slips ons sato, arata, akro, arrow, or any other high end one will give you 10+ with a custom map full systems will do 14 or so on average however the main advantage of a full system is the weight advantage. full systems (especially the titanium header ones) will take off max amount of weight. for in depth research go to 1000rr.net and check out the exhaust database. it gives exhaust info to include hp gains of various pipes ti headers are just fine for street use |
ORIGINAL: baxsom you can mod it the day you bring it home. |
slipper clutch, brake upgrade (preferably Brembo), braided lines, rear sets, Ohlins forks. I can't believe Bax did not include Two Brothers in his high end exhaust examples, bahh humbug. Have fun doing the mods, as I am learning, they never stop.
.........then after all that, you can invest in the best modification any rider can ever make.........a superbike school.
ORIGINAL: bergs ORIGINAL: baxsom you can mod it the day you bring it home. thats it the amount of air and fuel is not going to be affected by the wear of the motor. considering motor break in is only 300 miles (directly from honda's owners manual) i think he will be good tunung is controlled by the ecu and augmented by a pc3 true you wont see the max hp the tune is creating because of a tighter motor but the air fuel will not change just because parts are wearing in. the only mechanical parts that would mess with air fuel are the valves and thats only if they dont seal all the way. one would assume that they seal completely even after being broke in otherwise the bike wouldnt build compression and start at worst get it tuned. and take it back in a couple thousand miles and get it tested again. the hp will be up and the same map should still be on (not accounting for differences in air pressure or temp of course) but thats just my research based opinion, everyone is free to form their own. the above rant is pretty much verbatim of the dyno tech here at Velocty Dyno in san antonio |
Don't need a superbike school since I've been riding, racing, track riding, and dirt biking for 18+ years. I just haven't kept up with the new technologies(Fuel Inj, PC3, etc). My last bike wasa carb 1999 R6.
Guys, Thanks for the info. |
| All times are GMT -5. The time now is 07:25 AM. |
