Questions for the experienced guys...
Old Jun 21, 2006 | 02:47 PM
SirJAG's Avatar
Default Questions for the experienced guys...
i have read on the gixxer forums about a TRE (timing retard eliminator). its basically a signal to the ecu that the bike is still in the lower gears to limit torque. and a way around that is intall a resistor to trick the ecu into thinking the bike is in 5th.
does honda do anything like that?.....
http://www.gsxr.com/showthread.php?t=1789
Old Jun 21, 2006 | 05:56 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Default RE: Questions for the experienced guys...
Negative -- you are fully torqued in all gears on the bird. You are limited to 186mph though unless you get the HRC brain.
Old Jun 21, 2006 | 06:15 PM
gixxereater's Avatar
Actually, a speedohealer will take the 186 limiter off as well and it's only $80, but i Honda doesnt make a bike that fast yet so that's irrelavent. Someday maybe.
CBRF4600
Jan 15, 2014 06:55 AM
cobra989
Dec 8, 2012 10:02 PM
ahbrown4057
Apr 24, 2011 12:53 PM
NorthernF1
Aug 24, 2009 06:27 AM
Air4Andy
Sep 8, 2005 02:23 AM
