PC install 06 1000RR
Old Jul 26, 2007 | 06:53 PM
mihomie's Avatar
Default PC install 06 1000RR
Yes I searched for a thread for the past two days and can not find the one I once looked at.So please do not flog me on this one.
I plan to order a commander tomorrow and have a quick question before I get deep into it. Although it appears to be a very simple install there has been previous postings about which injectors were connected. The directions do state to connect to the lower set of injectros, which are the primary injectors. However the picture in a previous post I believe showed the upper fuel rail disconnected.
My question is whether or not the connnectors can be accessed with out removing the upperrail/injectors or what ever it was this person had loosen or moved.
thnx
Old Jul 26, 2007 | 09:32 PM
brendan1026's Avatar
Registered Users
Default RE: PC install 06 1000RR
The upper fuel rail and injectors do not getdisconnected during the install of the PC.
Old Jul 27, 2007 | 04:59 AM
baxsom's Avatar
put it this way
if the injectors are easy to get to
you are using the wrong ones
go here
there is a link with a picture laden install
http://www.hooliganbiketech.net/hond...frameindex.htm
Old Jul 31, 2007 | 11:06 AM
OldGuy61's Avatar
yeah don't touch the upper ones. The orange wire connector goes on the far left one (#1) and then go from there. It helps if you have small hands..
The one thing I messed up with was not disconecting the drain hose you're supposed to when rolling the fuel tank upwards, and I lost the little joint [:@].
jeroen83
Apr 4, 2014 06:52 AM
shizz
Apr 1, 2009 10:55 PM
McCullough
Mar 29, 2009 07:22 PM
TheFactor
Jul 8, 2008 10:19 PM
