Lowering the Front on 2006
Old Nov 22, 2006 | 03:41 AM
DavidsCBR1000's Avatar
Default Lowering the Front on 2006
I installed Diamond Lowering links on My 06. I tried to lower the front but couln't figure out how. It has the electronic stabalizer. Do I have to remove it to lower the front? I was going to remove the triple clamp, then the Clip on's, then slide the triple clamp back on the fork tubes then mount the clip ons above the triple clamp. The stabelizer was in the way. I took off the plastic covers, then 4 bolts, but it didn't come loose. Do I have to pull the Tank? anyone done it yet?
Thanks,
David
Old Nov 22, 2006 | 04:18 AM
Boosted521's Avatar
Default RE: Lowering the Front on 2006
can you not just adjust the forks?
Old Nov 22, 2006 | 12:16 PM
FATHEADS1KRR's Avatar
Yea, you gotta remove it, but not the tank, the tank cover. Just remember that there is a locating pin molded into the clip-on that "locates" it in relation to the upper clamp. You'll see what i'm talkin when you get it off. Can still be done, but you wanna make sure you get it back on REAL tight so it doesn't swivel on you. It can't go down, won't go up, but could turn if its not tight enough. There are some other little adjustments you'll need to make too, like the throttle cable, brake line clamp. banjo fitting on left clip on, that sort of stuff. None of it is that hard, just takes a lil tinkering w/.https://cbrforum.com/m_133615/tm.htm this might help some, and if you still have questions, i would be happy to help.
Old Nov 22, 2006 | 05:21 PM
Thanks, I will be more confident knowing what to look for.
David
Old Nov 22, 2006 | 08:58 PM
baxsom's Avatar
out of curiosity
why lower
i thought the 1krr handled better in the twisties if you raised the front
Old Nov 22, 2006 | 11:21 PM
MgA_ODEN's Avatar
ORIGINAL: baxsom
out of curiosity
why lower
Short rider.
Old Nov 22, 2006 | 11:43 PM
baxsom's Avatar
fair enough
but if you lower the front you need to lower the rear as well
i am no suspension expert but from what i understand and have read
the general consensus is that this bike responds better when it is flat
Old Nov 23, 2006 | 02:45 AM
MgA_ODEN's Avatar
ORIGINAL: baxsom
fair enough
Did you read the first post?
cbr baz
Dec 7, 2011 05:58 AM
jtboyd91
Jul 23, 2010 08:24 PM
G3NESYS
Apr 3, 2009 01:12 AM
Doodie
Sep 3, 2006 02:58 PM
Eric CBR929
Aug 4, 2006 06:33 PM
