Jardine RT-One Dual Outlet Exhaust Question.
Old Jun 22, 2007 | 12:32 AM
SproutRR's Avatar
Default Jardine RT-One Dual Outlet Exhaust Question.
Good Evening All,
I just installed the Jardine exhaust and no matter what I do, I cannot keep the new s-pipe from shifting over and rubbing the end of the screw that holds the stock rear brake fluid resivor on. I have loosened it, moved it over and tightened it back down, but it always shifts back over within the first ride. Has anyone else had the same problem? If so, what did you do to fix it?
Thanks,
Sprout
Old Jun 22, 2007 | 01:10 AM
AudiCBR's Avatar
Default RE: Jardine RT-One Dual Outlet Exhaust Question.
try locktite on threads
Old Jun 22, 2007 | 01:56 AM
SproutRR's Avatar
I do not believe the locktite would work because the bolt is stayingtight.
Old Jun 22, 2007 | 04:29 AM
bboi's Avatar
shortin bolt on res., or relocate brake res. only way to do it. also I talked to the guy who installed mine and he said it doesnt matter if it touches the bracket, it wont harm it. he vouched for it so I gotta trust him.
Old Jun 23, 2007 | 04:58 AM
SproutRR's Avatar
Thank you both for the suggestions. I found the answer lastnight after thinking about it for awhile... I knew it would not affect anything by touching the bolt, but it made an odd sound when it vibrated against that bolt and it would drive me nuts while waitingat stop lights etc.The fix to keep it off the bolt is to use both spacers on the left side of thesubframe mounting position, instead of one on each side. This will ensure enough clearance on the right side once tightenedno longer touching the bolt. I have test rode it and it did not shift back. Thanks again for the suggestions.
Old Jun 28, 2007 | 04:07 AM
mmookey's Avatar
I used to have a Jardine exhaust and the spacers were different sizes to accomodate the clearance issues. Are you sure that you put the right spacer on each side?
Old Jul 11, 2007 | 09:00 PM
SproutRR's Avatar
Both spacers are the same thickness. I will call Jardine in the morning to see if they are now including new spacers. Thanks for the input.
Sprout
Old Jul 12, 2007 | 09:14 AM
n0s_speed's Avatar
how's the sound of the jardine? andhow much did it cost? if you don't mind. i'm also looking forward on buying a jardine or arata exhaust. just not sure which one.
Old Jul 12, 2007 | 05:51 PM
openclasspro's Avatar
ORIGINAL: n0s_speed
arata- top notch quality and craftsmanship=loud ,but very refined sound- fills out the tail section of the 1krr beautifully- see brad at www.superbikesupply.com for the best price-phil
BBLineBacker81
Apr 20, 2008 09:00 AM
SproutRR
Mar 19, 2008 10:20 AM
1k06rr
Aug 15, 2007 02:52 PM
Tony2wheels
Apr 27, 2007 01:44 AM
