HRC RACING AIR DUCT??
Old May 25, 2006 | 01:28 AM
Seltorque's Avatar
Default HRC RACING AIR DUCT??
Has anyone fitted an HRC Racing Air Duct to their bike? If so? What was the result?
Old May 25, 2006 | 02:05 AM
RetroSBK's Avatar
Default RE: HRC RACING AIR DUCT??
on the dyno, wihtout ram air, it was 4-5 hp. Should be a bunch more at speed.... like 8-10
There are a couple of companys that have done knock offs of the HRC duct for a lot less, I think OPP is one, but I havent used that, only the HRC and the Ten Kate unit.
Will
Old May 26, 2006 | 02:30 AM
blade17fire's Avatar
HRC racing air ducts?? wat is dat?? velocity stacks??
Old May 26, 2006 | 07:22 AM
Seltorque's Avatar
I see Blade17fire have the flapper mod. So if you look at the flapper that is the Air Duct. What the HRC improves on is that supposedly to increase airflow by as much as 40%. Therefore more air = more fuel= more POWER!!!!!
You also have velocity stacks, where you get them from? and how much? I have seen them for about 80bucks each!!
Old May 26, 2006 | 04:54 PM
RetroSBK's Avatar
The HRC Velocity stack set is $550 a set...
Get the kit airbox too...
Honestly, there is more power to be made from doing cams, kit valve spring, and ECU.... But it doesnt LOOK as cool... lol
Overall, if you dont have Forged mag or CF wheels, thats the best bang for the buck!
Will
Old May 26, 2006 | 05:02 PM
JeffRR's Avatar
ORIGINAL: RetroSBK
Will
Whats it look like. Any pics?
Old May 27, 2006 | 12:59 AM
Seltorque's Avatar
****!! that is some serious money for stacks. The kit airbox? What do you mean? Change the airbox completely? I was thinking, Stacks + racing duct + Air box = serious amount of money. Wonder if the gains are worth it. The air box I presume is from HRC right?
Old May 27, 2006 | 02:29 AM
jaxx1671's Avatar
i personally like the one from OPP and you can chose from three diff material types.....
Old May 27, 2006 | 02:56 AM
Seltorque's Avatar
jaxx have you got one fitted? If so? what is it like?
Old May 27, 2006 | 05:31 AM
vipercwf's Avatar
So is there a HRC kit for the 06 1000? If so what does it consist of and where can I get it?
