HELP, parts are here.
Old Jun 20, 2008 | 03:01 PM
BigCountryBllr's Avatar
Default HELP, parts are here.
I have an 05 CBR100rr. STOCK!
Ijust got hot bodies flush mount front turning signals, and LED intergrated tailight, and licence plate bracket with lights(mounts under battery tray)
Will i be able to do this myself? Any special tools needed?I saw a video on"Youtube"and someone used sodder..
Am i going to need extra resistors to slow down the blinking speed?
Any tips?.. I really hope i dont mess anything up...
Old Jun 20, 2008 | 05:38 PM
Onarom's Avatar
Default RE: HELP, parts are here.
You can do it by yourself. The solder isn't needed, it is just a more permanent way to ensure your wires are connected.
You don't need to slow down your blinking rate unless you really want to. Personally, I kind of like mine blinking faster.
If you can, I would use heat shrink instead of electrical tape. You should be able to find some at about any hardware store.
If you mess up, you will probably only blow a fuse. Just read the instructions first and you should be fine!
Oh yea- TAKE YOUR TIME- don't be in a hurry. That is my best tip for you.
lxxxvii_xc_cbr
Aug 28, 2008 12:03 PM
