exhaust servo
Old Apr 4, 2008 | 09:57 PM
KILLER EX's Avatar
Default exhaust servo
can you unplug and remove the exhaust servo on an 05 when you install a slip-on ? will it cause any problems? thanks[/align]
Old Apr 5, 2008 | 11:56 AM
Volksdragg's Avatar
Default RE: exhaust servo
If you just unplug it, your MIL will stay on, on your gauge set. Just tuck your cables up and away.
Old Apr 6, 2008 | 12:27 AM
mcwheelie08's Avatar
does thiis effect performance at all and do you have to secure the flapper open somehow
Old Apr 7, 2008 | 02:53 PM
lowlife's Avatar
ORIGINAL: Volksdragg
I stuck my Akra on over the weekend and took the cables off. Was this a bad thing should a put cables back on
Old Apr 10, 2008 | 03:58 PM
teddi's Avatar
it doesn't anything. u might get more low and midrange.
Old Apr 20, 2008 | 01:48 PM
JK1000RR's Avatar
I took the cables and servo off. How do you get that stupid light to go out?
Old Apr 20, 2008 | 02:19 PM
MgA_ODEN's Avatar
ORIGINAL: JK1000RR
Plug the servo back in.
Old Apr 21, 2008 | 12:23 PM
JK1000RR's Avatar
great, the servo is long gone taken by the trash man. any other suggestions? thanks
Old Apr 21, 2008 | 03:12 PM
MgA_ODEN's Avatar
http://cgi.ebay.com/ebaymotors/HONDA...ayphotohosting
Old Apr 21, 2008 | 05:52 PM
JK1000RR's Avatar
thanks for the suggestion of buying another servo, however ithink there has to be something else to disable that light so that the eCU isnt confused. Are there any racers out there that have removed this thing???
