Dyno results
2007 CBR1krr
Yoshi full exhaust
K&N filters
PCUSBlll
1st pull 89.0F 58% Humidity Pressure 29.9 12:49 PM 147.4HP 78.39FT LB
Final result 149.0HP 78.42FT LB
Any comments or suggestions I was thinking it would break into the 150HP range?
Yoshi full exhaust
K&N filters
PCUSBlll
What kind of dyno was it? Certain dyno's are more accurate than others. Dynojet numbers are usually considerably higher than say Factory Pro or Superflow dyno's. True HP on this bike was actually only 138ish, the numbers you see in the test are not TRUE hp so your 149 hp might be damn good. Check out Factorypro.com and read the true hp section.
Hey thanks for the link the name of the dyno is sportdevices (sportdyno v3.2) www.sportdevices.com
This is a good Dyno and it will read lower numbers, if you convert to Dynojet numbers which you see on the test your probably at 160 +. Those are great numbers and you should eat up stock bikes.
