Comp Werks fender eliminator
Old Jun 29, 2006 | 12:50 PM
dizzie56's Avatar
Default Comp Werks fender eliminator
I just got the comp werks fender eliminator and i took everything apart on my bike but dont have a clue on how to do the wiring. Am i suppossed to cut the stock wiring and if so where and how do i attach the wiring for the rear turn signals to the stock wires?
Old Jun 29, 2006 | 01:04 PM
wolvrinewd's Avatar
Default RE: Comp Werks fender eliminator
I just cut the wiring off the stock turn signal bulbs and rear light and sodered them to the turn signal wires and then just plugged them back in.
Old Jun 29, 2006 | 01:32 PM
ShoHonda's Avatar
I used the same stock connectors that you had to un-do in order to take the fendor off, but then cutt the wires from the fendor at the base of the fender to give me plenty of slack. Used the connectors from the supplied kit and then wrapped them up in electrical tape. One thing I did in order to make sure everything worked correctly, I hooked up one light at a time then tested it. Once it passed, I then completey wrapped it up. This ensures that all wires are secure and you have the left hooked up to the left etc.....
Old Jun 30, 2006 | 09:53 AM
Socrates's Avatar
Yeah...I had the same problem..the instructions were not the greatest. You definitely need to cut wires from the stock fender and connect them to the kit. The only thing that drove me nuts was how to use the friggin pink connectors ??? I stripped the wires and twisted the copper together with my fingers...and then wrapped in electrical tape. Yeah I thought it was going to be a 45 minute job...but took me 3 hours ....
Old Jun 30, 2006 | 03:08 PM
cbr04's Avatar
hmm... that's weird because the CW kit I got for my 600RR was plug-n-play - no cutting/splicing necessary. That's odd CW would not do the same with their 1000RR kits
Old Jun 30, 2006 | 03:41 PM
dizzie56's Avatar
yeah definately not plug and play. u would figure for the amount of money that the kit cost they would be able to put the stock plugs on the wires.[:@]
Old Jun 30, 2006 | 04:43 PM
cbr04's Avatar
No kidding! CW kits aren't exactly the cheapest on the market [:@]
Off note here but I hear the bike scene in Clearwater is pretty nice. I'm in Lakeland right now on vacation.
Old Jul 2, 2006 | 10:47 PM
kryptonite_cycle's Avatar
installed one myself took a few hours but looks good
Old Jul 3, 2006 | 10:58 AM
dizzie56's Avatar
I finally installed it and it looks great. The only problem is that the next morning i guess the right taillight blew and it caused a short and blew a fuse while i was doin 90 over a bridge so all my gauges turned off at the same time. Now i cant find the damn right size bulb to fix the problem. Im freakin pissed. There is no way it should have blown already!
Old Jul 4, 2006 | 03:13 AM
CBRage1000rr's Avatar
badass !!!![IMG][/IMG]
[IMG]local://upfiles/8907/865A92BA66964E4D8A07E85F0CCFC234.jpg[/IMG]
http://vids.myspace.com/index.cfm?fu...=568420750&n=2
