ARATA Leak
Old Sep 24, 2005 | 11:04 AM
jmere67's Avatar
Default ARATA Leak
Has anyone heard of ARATA S/O having problems with it leaking? Trying to chose either SATO or ARATA?
Please help!
JP
Old Sep 24, 2005 | 01:13 PM
MgA_ODEN's Avatar
Default RE: ARATA Leak
Nope.
Old Sep 24, 2005 | 02:31 PM
sirlimpzalot's Avatar
any pipe has the potential to leak, but it is easily cureable with the proper tools and equipment..but I have not heard about this problem you mention..by leaking you mean exhaust leak right?? and where is it supposedly supposed to have this problem?? the headpipes, the mid pipe??
Old Sep 24, 2005 | 10:17 PM
jmere67's Avatar
I have heard the xhaust leak is coming from the mid pipe! Trying to rule out before I make a decision of either to SATO or ARATA!
Thanks!
Old Sep 24, 2005 | 10:26 PM
chainstretcher's Avatar
Admin Emeritus & MVN
The higher end pipes usually won't leak as long as you install them properly. Sometimes that means taking an extra 30 minutes to check stuff. Some people tend to rush the install and then blame the manufacturer. Not saying this is always the case but, knowing the peeps I know, certainly within the realm of possibility Either of the pipes you mention is a good pipe -- I prefer the 2Bros ... but that's just me.
Old Sep 24, 2005 | 11:29 PM
MgA_ODEN's Avatar
The only mid pipe leak I've heard of was when some retard forgot to install the factory clamp.
Old Sep 25, 2005 | 07:50 AM
Anubis's Avatar
Between the two you mention i`d go for Sato, alot more race proven quality and i`ve seen a few examples and the build is second to none.
Old Sep 26, 2005 | 05:17 AM
jcf1977's Avatar
I've had ZERO problems with my Arata. I have the "new style" design that fills the void under the fender. I would have to say that maybe the leak was caused by the installer not seating all the clamps and gaskets properly. I have a hard time believing that Arata would build a leaky pipe but who knows, NO company is perfect
Old Oct 6, 2005 | 10:03 PM
Oni23's Avatar
that retard would be me..[:@]
i cut a strip of gasket and wrapped the Ti midpipe to protect and then tightened the shyt outta the stock clamp. i dont think i got leaks anymore... bike sounds meaner..
ORIGINAL: MgA_ODEN
06BlackPearl
Mar 1, 2009 08:00 AM
Andres
Sep 18, 2008 10:39 AM
bornluckee13
Apr 30, 2007 04:47 PM
Daca
Apr 24, 2007 11:40 PM
hondafanatic
Jun 21, 2005 03:45 AM
