ARATA Leak
any pipe has the potential to leak, but it is easily cureable with the proper tools and equipment..but I have not heard about this problem you mention..by leaking you mean exhaust leak right?? and where is it supposedly supposed to have this problem?? the headpipes, the mid pipe??
The higher end pipes usually won't leak as long as you install them properly. Sometimes that means taking an extra 30 minutes to check stuff. Some people tend to rush the install and then blame the manufacturer. Not saying this is always the case but, knowing the peeps I know, certainly within the realm of possibility
Either of the pipes you mention is a good pipe -- I prefer the 2Bros ... but that's just me.
I've had ZERO problems with my Arata. I have the "new style" design that fills the void under the fender. I would have to say that maybe the leak was caused by the installer not seating all the clamps and gaskets properly. I have a hard time believing that Arata would build a leaky pipe but who knows, NO company is perfect
that retard would be me..[:@]
i cut a strip of gasket and wrapped the Ti midpipe to protect and then tightened the shyt outta the stock clamp. i dont think i got leaks anymore... bike sounds meaner..
ORIGINAL: MgA_ODEN
The only mid pipe leak I've heard of was when some retard forgot to install the factory clamp.
