Air Intake Flapper Mod
You should make LDH's webpage a sticky [&:]
This page will be devoted to the CBR1000RR with product reviews, step by step detailed mod instructions & just as importantly we will also answer the questions of why we are performing each mod & what advantages or disadvantages they produce.
I removed the flapper and vacuum can and assorted crap. Unless you have a manual, lots of room and above average mechanical skills I'd suggest leaving it in. This is the first time 'under the hood' and I'm impressed with all the doo-dads and **** in there. I'll let ya know after a couple hundred miles how it runs with the physical stuff gone.
i did this mod like the 2nd day i got my bike after a friend of mine told me about it , i now have about 3000 miles on my bike and other then the charging problem im having now the bike ran the same that i could remember , to me the bike gets louder and has some more throttle response just like as u would put an intake on a car .
I had the mid fairings off last night to install my Greggs Customs signals, so I took the opportunity to remove all the associated crap with the flapper. Removed the valve/solenoid assembly on the left side of the bike and plugged the vac line to the motor. Even if it doesn't make much difference, it gets rid of some of the clutter on the bike. I did notice a vacuum line running from the motor (can't really see where) that had the end just stuck into the hollow opening on the left side frame spar. What is this and is it supposed to be there? BTW, the Greggs Custom signals look great. I think I may cut them off though to install resistors on them. Not sure I like the hyper-fast blinking, sort of reminds me of all the dumb tricked out Honda Civics I see all the time.
