Aftermarket Resistors?
Old Jun 16, 2007 | 06:49 PM
birde's Avatar
Default Aftermarket Resistors?
when i put my clear alternatives on my old 929 i bought an aftermarket resistor but i have no clue what it was... now i put it on my 1000rr and i have no clue where i bought it from (the resistor) if anyone could help me out id appericate it... i think it cost me like 30 bucks last time
Old Jun 17, 2007 | 12:10 AM
2007cbr1000rr's Avatar
Default RE: Aftermarket Resistors?
I just put in my clear alternatives smoked today. I used a non load dependant relay from custom led.com. I believe it was 20 bucks or so and will work with any combination of led's. The stock relay is located under the left upper faring and it simply replaces the stock one. I also have led fronts and they flash correctly without having to worry about resistors heating up and melting my plastics. Hopethis helps.
Old Jun 17, 2007 | 12:37 AM
hondadriver4life's Avatar
ok so i dont know about the whole resistor issue becaus ei cant get the damned thing to fit into the stock wiring harness!!!!!!!!!! ive got an 05 1krr and need some help.......
Old Jun 17, 2007 | 01:07 AM
What brand of light are you using? Does the connector have 3 wires in a triangle pattern.. 2 on one side and a on the other?
Old Jun 17, 2007 | 01:25 AM
Well.. either way the connector on my light was insanely tight. Mine had excess plastic all around it. Even with that trimmed off I had to put the 2 ends in my hand and squeeze like hell.
Old Jun 17, 2007 | 07:23 PM
CBR1000's Avatar
http://i210.photobucket.com/albums/b...res5-07144.jpgIs this what your looking for?
If not this is what I would reccomend. It's a relay. The resistors require alot more work. This just plugs in.
Old Jun 17, 2007 | 07:44 PM
ORIGINAL: 2007cbr1000rr
i have the clear alternatives integrated tail light and the problem is that when i went to connect the tail light, the two connectors wouldnt fit together........ if that makes any sense lol its like the clear alternatives tail light connector is not shaped right.... square peg round hole kinda deal lol
Old Jun 17, 2007 | 08:56 PM
birde's Avatar
that might be it... imma ask my buddy if i can take a pic of the one off my old 929 and see what it is
Old Jun 18, 2007 | 02:23 AM
Rampage's Avatar
$1.29 10 ohm resistor from radio shack. works perfect.
Old Jun 18, 2007 | 03:03 PM
WolfPack's Avatar
wish i would have thought about the digital-relay before i solderd those monster-*** ceramic resisters in-line on my harness........ what really makes me mad is that i replaced my truck flasher relay with one of them about a week before i did my bike...lol
i may cut them out of my wiring loop and do the relay this weekend....if its like my truck...it clicks really loud so i might not leave the blinker on as much...
