520 Chain and Sprocket Conversion
Old Dec 10, 2006 | 08:07 PM
  #31
repsol73's Avatar
Default RE: 520 Chain and Sprocket Conversion
What up fellas. I have a question for you all. I did the 520 Conv. on my bike 16t front/43t rear DID chain. Well everything came out ok except that when I shift gears they feel really hard and now shifting into 1st gear, it hits harder than before. Also all the other gears hit hard now when before, they never did. Any suggestions? Once the bike is rolling it feels smooth, the chain tracks smooth and straight.
Old Dec 16, 2006 | 03:35 PM
  #32
Bracey0self's Avatar
i love my conversion. nicer ride plus looks a lot better if you keep it clean.
Old May 24, 2007 | 06:58 AM
  #33
Merlin's Avatar
Nice post.
I do extacly the same move.( in my bike for the races)
More lighter chain .
Old Jun 6, 2007 | 06:27 AM
  #34
Roach's Avatar
ORIGINAL: repsol73
Hey Repsol73, did you solve the trouble you were having with the hard shifting???? I am wondering if it is the new front sprocket that is not dampened like the stock one. Also, maybe a tight chain.
Let us know what you came up with.
Later
Roach
Old Jun 6, 2007 | 11:30 PM
  #35
baxsom's Avatar
well remember aftermarket front sprockets do not have that rubber dampner
so that will cause more vibration and more "felt" clunk in the drivetrain
but as far as always clunky check your chain, if it is too tight the shift will be hard as well
also make sure and check the verticle shift linkage to make sure the linkage rod is at a 90 degree angle to the shift rod coming out of the motor.
Old Jun 23, 2007 | 07:04 PM
  #36
jhcole100's Avatar
How much would I pay at a bike shop for this mod?
Old Sep 16, 2007 | 02:54 AM
  #37
NeverL8's Avatar
i've been wanting to do this but should i wait til i need to change something out? like the chain? thanx.
Old Dec 22, 2007 | 07:57 AM
  #38
CBRflyr's Avatar
I've been using the 520 DID for about a year. Improved the low end a little bit. I've been told it's best to put on new sprockets the same time if you have few miles on it, otherwise the chain will wear out prematurely
CBRflyr
Old Dec 23, 2007 | 11:57 AM
  #39
Onarom's Avatar
Thank you for this write-up. Great job!
I will be using this in the near future.
Old Jan 9, 2008 | 05:44 PM
  #40
Onarom's Avatar
I finally did my 520 conversion. You clear instructions definately helped! I had my laptop next to me the whole time I was working on the bike. Thanks again
