1000rr mods
Guest
Posts: n/a
ORIGINAL: Pamw
if it is possible to do it on a 1000rr...chances are I have done it......ask.
I could answer that post in many ways??
..buy I am a gentleman and I am not going down that road miss
OMG..I hate the head light. Honda is so stupid. I am trying to find dual element bulbs so i can do that. and you just ad a cross wire to the opposite plug. I just have had other more important things to do . i will step up the search or see if a simple mod can be done to use a different bulb. I thought about HID but don't like how it looks.
YES change the brake lines to Galfer or goodridge.....chnage the clutch line to. believe it or not under hard breaking and definately over time the rubber lines sponge. and also the brake fluid does break down the rubber. on cars I have had the lines decay from the inside. the outside looked fine but the inside had decayed and swelled so that when you applied brakes...they worked fine...but when you released the swelling prevented the brake fluid from returning, thus basically making your brakes drag and the longer it goes the worse it gets. the SS lines are not rubber at all, they are a teflon tube with the SS mesh braid ove it.
