06 Cbr 1000rr
Old Jul 14, 2010 | 03:50 PM
not_agn's Avatar
Default 06 Cbr 1000rr
I just picked up a 1000rr . I have a 954 with the shift pattern reversed. I was wondering if there is a way of reversing the pattern on the 1000? Let me know. Thanks. Lee.
Old Jul 22, 2010 | 10:43 AM
CBRCRF's Avatar
What is the pattern on the 954? 1- down 5-up?
You can get a GP shift kit that will reverse the pattern. Stock is 1-down 5-up, GP is 1-up 5-down.
* I dont own one. So My info might be off*
Old Aug 5, 2010 | 08:39 PM
2003F4iDude's Avatar
No way to just flip the shift arm to make it reverse on the 1000rr you have to buy the GP shifter, i got a Gillies Gp Shifter from Brad at Super Bike Supply and it bolts right on with the stock shift linkage and it rocks!
Old Aug 12, 2010 | 07:07 PM
TheuncannyJ's Avatar
Yup. Just buy the GP shift kit and be done with it.
Old Aug 12, 2010 | 07:48 PM
Amen
Old Aug 2, 2016 | 08:43 AM
Jaybird180's Avatar
I'm looking for contact information now. I'm working on a pre-purchase inspection on a 2006 10000RR and I can't do standard shift, too much to think about. I need to switch it to GP ASAP.
Old Aug 2, 2016 | 08:44 AM
Jaybird180's Avatar
Meant, I'm looking for Superbike Supply as mentioned above.
Old Aug 2, 2016 | 02:41 PM
coalminer frank's Avatar
Last I heard Brad from SuperBike Supply either sold it or shut it down. 1000rr.net might help.
Old Aug 2, 2016 | 06:14 PM
Jaybird180's Avatar
Thanks. I bought the 1000RR. It needs a little TLC, then it's upgrade time!
Old Aug 2, 2016 | 07:44 PM
No Jaybird180, I didnt ask you if you checked it out, I meant check out the web site "1000RR.net" Its completely dedicated to CBR1000RR's. All years. That should help you find a solution to your GP shifting you want. I believe you need aftermarket rearsets or some kind of different linkage. You cant just flip the linkage like I did on my 08 1k because the hydraulic clutch thing is in your way.
