04 1000rr won't go into gear
Old Jul 14, 2010 | 04:46 PM
Nathan Haney's Avatar
Default 04 1000rr won't go into gear
Alright guys i have a 04 1000rr with around 18000 miles on her. I am the only owner and have never had any issues. But now it won't come out of neutral. It worked fine one day then the next when i started it up only neutral...Anybody have any ideas? I don't want to break out the vaseline and take it to the honda dealership
Old Jul 18, 2010 | 01:14 PM
chainstretcher's Avatar
Admin Emeritus & MVN
There is no way to know for sure until you open her up. The good news is that the '04 1kRR has a cartridge tranny and is relatively simple to get into.
If I had to hazard a guess I'd say shift fork bit it. How does the shifter lever feel? Springy like usual but just won't click into gear?
Old Aug 5, 2010 | 08:41 PM
2003F4iDude's Avatar
+1 sounds like a bent shifter fork unless the clutch is worn out or there is a lot of air in the lines may need to be bled, good luck
Trent Dog
Jul 9, 2012 06:32 PM
