1000 Modifications This section is specifically for questions and advice pertaining to mods of the current 1000 models.
PCIII Maps for the 1000RR
Old Nov 8, 2005 | 12:52 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Default PCIII Maps for the 1000RR
If you have a map that works great and you wanna share, e-mail it to me at webmaster@chainstretcher.com and I'll post it here.
Make sure to list all your pertinent mods (stickers don't really add HP) along with your screen name so I can give you proper credit.
Disclaimer: Using someone else's map may cause your bike to perform poorly even though you have similar mods. Exercise good judgement when testing new maps and always save your current settings so you can go back if necessary.
Directions: Depending on your set up, you may be able to just click the link and the program will automatically load up the map. If this doesn't work then just right click on the link and hit "save target as ..." then open it up from the PC-USB program.
Old Nov 8, 2005 | 06:10 PM
Default RE: PCIII Maps for the 1000RR
Dan Kyle Map
Application: Stock exhaust and air filter.
Submitted by: Anubis
Comments: smooths out the fueling under 4k revs where the original map runs rich at low to medium throttle openings.
Anubis' Personal Map
Application: 04 Model, Air Intake Mod, K&N Air filter, Yoshi RS5 Slip On
Comments: pulls hard from 2000 revs which it never did prior to the adjustments in the map.
evilbastard
Application: LeoVince full race exhaust with 60mm SBK Ti Can - no baffle. Flapper mod. OEM air filters with snorkels.
Submitted by: evilbastard
Comments: This map is still a little rich in some spots but it's ten times better then any of the maps I've tried. I used a LM1 wide band O2 meter with data logging on the TPS, RPM and MPH to tune this map. Do not use the PC3 accell pump, honda already has one in the bikes efi.
Old Jan 31, 2009 | 02:45 PM
niknack's Avatar
hi i got a map off dynojet site i run 06 uk model fireblade with micron end can link pipe 02 eliminator and k&n air filter . had to use map for arrow can but it worked ok got rid of bottom end flat spot .but would reccomend a run on dyno map was very close 145bhp back wheel with a bit of fine tuning got 150hp dyno important so they can check your fuel air mix make sure its running correctly .. by putting map on yourelf saves time at dyno and money cheers guys simon
vancev
Aug 13, 2015 11:56 AM
f3racer
Aug 5, 2008 09:17 PM
sonic0123
Aug 16, 2007 12:44 PM
cmmoist
Jul 27, 2007 09:23 PM
Maniac33
Feb 17, 2006 10:36 AM
