My breaks are making noise
It seems that when i use my rear brake, the rotors, or pads make noise like squeek.
When the bike is rolling or moving, the front automatically makes braking squeeking noise.
Even when i dont use them, like when the bike is rolling forward.
And even when i do apply my front brakes, they squeek as well..
And the front and rear rotors look dirty.
I'll try to get pictures. ANdy hElp would be awesome.
Bike was never down by the way..
RE: My breaks are making noise
Probably have some glaze on the brakes. If you are a hard braker then this is common espescially on the rear brake because it is smaller and doesn't shed heat as well. It will wear off just don't ride your brakes too hard, and it will take time. I have glaze on mine after a trip to the track usually however many people even in every day riding can overheat the brakes. Some brake cleaner might help DO NOT USE A SQUEAK STOPPER. They ruin your brakes.
After riding for an additional 300 miles or so, the front brake/rotors still make metal scratching noise. I don't brake hard at all. its all @ at ease.
Im guess the front rotor and pads, or not properly assembled. or have been mis aligned causing them to rub when they roll.
Because i just met another cbr f4i rider 2005, and he rides with out noise, and had the bannana seat style, but that shoulnd't make a difference.
Thats my only problem that is frustrating me.
ORIGINAL: SpiritBreaker
ORIGINAL: RojerLockless
The F4i come with uber brakpads that iv' been told will never wear out, but the downside is they squeak sometimes... just ignore it you are fine
but they squeak and sound like two metals rubbing while i'm rolling and NOT braking.
