F4I Gauge Cluster LED Change.. Help needed
Old 03-12-2012, 08:07 PM
HowlPendragon's Avatar
Default F4I Gauge Cluster LED Change.. Help needed
Hello CBRForum,
I am currently in the process of replacing the stock LED with different color LEDs. This is my first time doing this and i ran into a bit of a problem. I already soldered the new LEDs into place but however i have four that are not turning on. I tested the LEDs to see if they all light up before resoldering the LCD panel and tach. However, four are not lighting up but i wonder if it's because i didn't solder it well, or if its a bad LED? and if only one isn't working is it gona make the rest of them not work. I was hoping if somebody could give me some feedback or suggestions on whether to either replace all four of those LEDs or what to do or how to test if it's a single one?
My cluster diagram looks like this. "X" marks the non-operational LEDs and "0" marks working ones.
X X 0 0
0 0 0 0
X X 0 0
Any help would be appreciated thanks.
Old 03-12-2012, 08:54 PM
jeffjones's Avatar
My guess is they are in backwards?
Here is my tutorial I did for doing it: https://cbrforum.com/forum/how-mecha...luster-119967/
Old 03-12-2012, 09:18 PM
Thanks for replying,
Thats the thing they're not.. the negative is facing the right way. Those six on the LCD panel all go the same way and they are. Should i replace them with new LEDs and resolder?
Old 03-13-2012, 12:03 AM
So i made sure they are the right way, the six on the side of the LCD screen go all the same way. These are pictures of my LEDs and the ones that don't work. Should i just replace them with new LEDs and resolder?
Old 03-13-2012, 06:41 AM
jeffjones's Avatar
I would just replace them one at a time and re-test.
Make sure you give a good clean/de-solder to the connection point to ensure a good connection.
It could be lots of different things, bad LED, bad solder, melting...
Just remember to put the least amount of heat needed as you don't want to melt stuff.
When its done you will love the look though.
Old 03-13-2012, 10:08 AM
Thank you Jeffjones,
I placed an order on some replacement LEDs and as soon as i get them i will resolder and repost with the end result. Thanks alot once again!
Old 04-01-2012, 01:09 AM
So it's been a while.. barely doing it now but this was the problem i was running into ..
but then i fixed it, turns out some LEDs were bad or didn't solder good.. cleaned it out and replaced them with new ones and this is the finished product.. first time doing it.
Thanks again for the help.
Old 04-01-2012, 09:16 AM
jeffjones's Avatar
Looks good, I hated the stock yellow/orange colour.
Glad you got it up and running.
Old 04-04-2012, 10:09 AM
Thanks Jeff,
It isn't that bad for my first time doing this. I had a question do you know by any chance how to reset the speedometer, the needle sits at 1k rpm instead of 0.
Old 04-04-2012, 11:52 AM
jeffjones's Avatar
Originally Posted by HowlPendragon
Thanks Jeff,
Mine did that to but before I put it back together I tested it and then just pulled the needle off again and moved it down abit.
stewyF4i
04-27-2015 12:39 PM
jeffjones
How-To: Mechanical
09-12-2014 02:31 PM
throttle out
F2 For Sale / Trade / Wanted
02-15-2011 01:19 PM
tdgroup
09-14-2006 01:42 PM
Quick Reply: F4I Gauge Cluster LED Change.. Help needed
