dying at low rpm's
dying at low rpm's
the past 2 days ive rode my bike it has died when slowing down. it starts great rides great just when it heats up a bit and im comeing to a stop light or something with low rpm's it will die. no lights come on or anything like that. yesterday i came to a small hill and i felt it getting lower rpms so i tried to give it gas and it took it a min to kick in. i pulled over turned it off back on and took off fine is this a sign my fuel filter is bad or going bad?
did the issue start right after you had the tank off? check around for vacuum leaks from hoses that may have been left off. also look to see if one of the fuel lines have been kinked. your idle set at 1300 is fine.
do you have a serviceable air filter that you cleaned? they will not idle worth a damn if they are a tad bit wet.
when you're looking around, see if there is fuel in the vacuum line at the FPR. it's a common failure part, and should be checked frequently.
NGK plugs are good.
your bike is fuel injected. that means the there are minimal adjustments that you can do, the bike takes care of that for you. if its not running right, there is a problem.
NGK plugs are good.
