01 Erion dead, won't crank
Old 04-04-2012, 10:06 AM
nightmarenyc's Avatar
Default 01 Erion dead, won't crank
Hey guys, was riding home and noticed my temperature was getting pretty high (260) and a red light started to flash right next to the neutral/gear indicator (mil?). Pulled into gas station, topped her off and let her cool down. Now she won't even crank. The red light is on solid, no flashes. I turn the key, hit the starter and I just hear a click from the starter relay and my headlight goes dim. I even tried running a direct line from the battery to the starter motor itself. Still nothing, just a click. Btw, the fuel pump is working as I hear it prime when I turn the key. Starter wiped out? I think I may have cooked it as my starter switch has been sticking lately. What do you guys think, as am gonna start tearing her open later.
Old 04-04-2012, 10:23 AM
74demon's Avatar
well, that sucks. does the motor turn over by hand? push the bike and try to bump start it. if the rear wheel locks up, and the motor wont turn over, you seized the engine. if it does turn over, and start hopefully, i'll guide you through "no crank" diagnostics. let's see if the motor turns first....
demon
Old 04-04-2012, 10:39 AM
I tried last night to pop the clutch by pushing it and she just sputters. The back wheel is not locking up. The fastest I could get her up to was 5 miles an hour as I was on pretty flat ground. I just wound up walking her home
Old 04-04-2012, 10:43 AM
74demon's Avatar
thats a good sign, but check into it further.
what is the voltage at the battery? sitting and when trying to crank.
Old 04-04-2012, 10:52 AM
Battery is fully charged. I tried starting it with it connected to my running van. Also been on the battery tender as well and it checks ok (green light). I'll check the voltage later when I get home and see where she's sitting at and where's she dropping down to. I even tried disconnecting the battery completly and jumping it with my van only and still the same thing
Old 04-04-2012, 10:57 AM
74demon's Avatar
check all the fuses. there is a fuse in the starter relay, if i remember correctly.
btw...never jump it from a running car.
Old 04-04-2012, 11:35 AM
Fuses are all good
Old 04-04-2012, 11:49 AM
74demon's Avatar
Originally Posted by nightmarenyc
Fuses are all good
even the hidden ones?
Old 04-04-2012, 12:12 PM
The fuse box, the starter relay and the other one in the white case attached to the fuse box. Are ther more?
Old 04-04-2012, 12:21 PM
74demon's Avatar
nope. thats it, you got them all. next step is to see if you have signal to the starter relay from the switch, and good voltage all the way to the starter. the switch may be the issue.
Quick Reply: 01 Erion dead, won't crank
