going to look at a '96
well i guess its time for a little update. Seems that the original frame cracked from the engine being mounted improperly. a PO snapped two of the side mounting bolts, and instead of removing the old bolts, drilled through them very crooked. Im pretty sure this is where the chattering was coming from. Anyway, I had my uncle weld up the bolt holes as they were WAY to wallered to helicoil. But with the engine being mounted the way it was, tweaked the frame just enough so all the mounting holes did not line up. Found a frame on ebay. stripped the crappy white paint off of it and found a couple small dents that had body filler in them, said screw it and took it to a local shop to get powder coated and am now in the process of getting her back together.
Might have the subframe and/or swingarm powdercoated in the future, want to see how it all looks once together.
Also decided to order some HK fairings, After repairing fairings on the two f3's I had, i had no desire to repair these.
I figured ill also mention that after my Uncle had welded up the mounting holes, he noticed something rattling around the engine when he tilted/moved it around. pulled the oil pan and out came an 8x32 flange bolt. After taking off all the engine covers and going over the engine with a fine tooth comb, finally found where it came from.
Also explains the cam chain rattle upon startup, CCT actually seems good. Luckily the only thing the bolt hit was the timing gear(still good though). Transmission appeared to be in great shape too, so that was a relief.
I got a 95 frame and swing arm sitting here. No title only paperwork sayins it wasnt stolen t-22B form I think. I was going to scrap it. shipping might be high though kinda heavy.
Frame isnt cracked just used. battery acid on frame under battery. Other then that its ok.
plan on coming to atlanta?
the issues have kinda sucked, but worst case scenario if I dont decide to keep it, ill break even.
