cleaned the dead gas out and wont start back
I cleaned out the dead gas and changed the plugs checked the filter because it was running like trash. Now it wont start back plugs firing fuel getting to the carbs dont know what the hell plz help bile was runnig before I done the work
Check and make sure the plug wires are on the right cylinders.
Open the drain screw on the carb bowl and see if gas comes out.
Pull the plugs and see if they are flooded.
Is the choke on?
Kill switch on?
Fuel petcock/valve on?
Did you take the carbs apart?
If that is good there is no reason why it shouldn't start. Maybe squirt some ether in one or two carbs, see if it tries to start
Is the choke on?
Kill switch on?
I have done all of that and it does fire with either and I did not take the carbs apart because if was running good enough that I did not need too. If the fuel pump is not putting out right but is still working could that be the problem. I have done everything that I know what to do. I am not a mechanic but I know the basics and it wont run from the fuel in the tank thanks for the help
Was that the fuel filter or the air filter you checked? (since you don't say which of the three) Maybe you knocked some crap loose and it clogged the filter.
I have checked both filters and pulled the gas line off the pump to see if it was working and the gas is coming out of the pump. The air filter was clean and the fuel filter was not that bad. The gas is getting to the carbs but they wont pick it up and run because the line has pressure where it splits off to the carbs. The carbs have gas in the bowls so I am at a lost. Guess I will have to put it in the shop and let the pros fix it
THANKS FOR THE HELP
THANKS FOR THE HELP
mine was in similar condition, I installed new spark plugs, air filter oil filter and oil. Then she started back up a lil rought on the RMP, my step-dad (a mechanic) told me it was a bad fuel/air mixture (carb synch). So I parked it for bout 3 weeks, then i tried to fire her up again and she just wouldn't start. Since I already need to to clean and sych the carbs I took it to the shop, they even thru in a tank wash free. Again she didnt start before going in and i didnt wanna force her to, so i just took it in and let them do their work and hand it back to me in workin order..hopefully..lol
WhiteHawk
05-30-2013 09:56 PM
