Carb removal help
Carb removal help
hey there so im trying to remove the carb off of my 99 f4 and im having trouble in not sure if im missing bolts or what but i just cant seem to get it loose i couldnt really find a write up on here so all the help would be appreciated. currently the bike is apart and i have loosened all the clamps on the bottom of the carbs.
Until you have followed the service manual procedures thoroughly, you may be increasing your chances of causing damage (I can't stress this enough). Be you are sure you are actually prepared to remove the carbs b/f you proceed. You can be *deliberate* but be sure you are ready to do so beforehand.
Also, chances are you're going to rip/tear those boots. Don't fret too much if you do...it would most likely happen w/a mechanic as well. Spray some wd40 on 'em to loosen 'em up.
Curious... Why are your removing your carbs?...for what purpose?...to clean? Has there been a problem or is this exploratory/etc?
