firing order
RE: firing order
Someone may want to step in here and correct me, but I don't think there is a firing order ( I know there is) in the way a car is. Like some V8's it might be 1-8-4-3-6-5-7-2. On the F3's there are 2 coils. When the coil fires, both plugs attached to that coil fire, but only one of the cylinders is actually on the compression/power stroke, so it fires. One coil is attached to cylinders 1 and 4, and the other coil is attached to cylinder 2 and 3. The cylinders are numbered 1 - 4 from left to right as you sit on the bike.
I hope this helps.
I hope this helps.
