F3 cutting out
i just had this problem with mine. here's the thread i started..might find some help there
https://cbrforum.com/forum/cbr-600f3-17/help-engine-randomly-cuts-out-dies-113343/
As will and dcaldwell have said it could possibly just be as simple as clogged tank vent line. I would try what willduce was saying with popping the cap and listening for any suction noise. If you hear it then you know the tank vent is clogged and needs to be cleaned.
If you dont, the list can go on and on. First thing we would need to know to help is how is it cutting out? Like just a bad miss then slowly sputters till it dies? Feel like its out of gas and bucking? Does it just shut off like you hit the kill switch?
Try what willduce said first and keep us updated and maybe we can get you going
i haven't got it out since i posted this so i still need to try popping the gas cap. but when it starts cutting out you can hold it wot and it wont rev out it stays around 3-4k rpm and if you pull in clutch it will die. one time i was cruising down the highway it started cutting out so i pulled in the clutch killed it while i just coasted for a minute, then started it up and it ran fine.
I was having a simular problem on my bike a few weeks ago with it just randomly dying while riding. The bike would just shut down like it turned the key off at any speed. The lights were flickering at idle and the bike would start bucking and stumbling before it died.
The gauges, headlights, and taillight all would just shut off along with the motor. The battery was fully charged though and the bike would start right up a few sec later and sometimes while i was coasting to a stop i got it started and rode off.
On my bike it happened to be just a dirty connector on the starter relay. The red connector with 4 wires was full off gunk. I cleaned it and havent had a problem since.
I dont know if thats anything like your having but hope it helps
