Voltage Rectifier/Regulator
Old 06-18-2006, 10:16 PM
suave's Avatar
Default Voltage Rectifier/Regulator
I recently replaced the voltage rectifier/regulator in my 91 CBR 600. It is now getting really hot, even on short trips. Does this sound like a problem with the rectifier or some type of insullaton issue?
Old 06-19-2006, 03:19 AM
MT Wallet's Avatar
Default RE: Voltage Rectifier/Regulator
Maybe check the wires too, the wiring harness that connects them to the bike's electronics... the Honda tech said when you change the rectifier you also have to change the wiring harness.
Old 06-19-2006, 04:17 AM
I believe mine might be shot...
My bike has recently been starting to act up, only after long rides with extended rest periods inbetween *over night* My bike starts up fine, just won't hold idle after its warm and dies. I checked the battery it seems to be fine... Also ive noticed that after long rides the battery its self is getting quite hot *And we all know where the better is located on our F2s >_> if you know what i mean.*
Is this an expensive fix?
Old 06-20-2006, 12:40 AM
suave's Avatar
I'll look into the wiring harness. Thanks.
Old 06-20-2006, 07:43 AM
MT Wallet's Avatar
Old 06-20-2006, 06:38 PM
Make sure your using the proper battery for your bike.I grabbed a battery out of a 250 ninja cause i just assumed since it was 12v it would work.It made my rectifier so hot that some brown crap melted out of it.I thought for sure it was toast.Somehow it is still good.
Old 08-22-2006, 01:27 AM
racer212's Avatar
Keep in mind that a regualtor is beasically a big heat sink that turns the excess voltage of your stator into heat, so a warm regulator is ok. One glowing red or melting **** is not. Basically if you battery will not stay charged, or that is wont idle but will run at hi rpm, this is likely the culprit.
Old 08-22-2006, 07:14 AM
Check your battery is ok, Not just the charge, check the acid level too, if its low top up with DISTILED WATER ONLY!!!!!
if its bone dry BIN IT!!!!, I know on the batterys it say don't remove the cover but it's their way of getting you to buy a new one sooner.
You check the electrolite in your car battery why not your bike??
asides
F2 Tech
06-25-2011 12:57 PM
Windsock209
07-22-2010 07:49 PM
terry1725
09-01-2009 07:50 AM
ememiya7
06-30-2007 12:31 AM
jzcbr600
04-01-2007 07:52 PM
Quick Reply: Voltage Rectifier/Regulator
