Loss of top end power
Old 12-28-2016, 08:50 AM
heresolong's Avatar
Originally Posted by dennisgb
I'm not positive on how the cut-out relay works but here's what I think it does.
With the relay in place the pump is not turned on until the ignition switch is turned to start. Without it the pump is on as soon as power is on. This could create a hazard in some situations.
+1 on everything except I believe the fuel pump is tied to the Start-Stop switch on the handlebar rather than the ignition switch.
  #82
Old 12-28-2016, 08:52 AM
dennisgb's Avatar
Originally Posted by shemwatson77
Is there a way to know how far to screw the choke adjustment screw that's attached to the carbs?
There isn't a choke screw adjustment. Are you talking about the black **** on the side? That is the idle speed adjustment. Normally the pilot screws are adjusted on the bike when warm and then the idle is set to spec with that ****.
If you look in the manual you will see the procedure.
sjwendte
03-08-2016 08:19 PM
03rep
07-06-2012 10:51 AM
Cokey83
07-01-2012 05:39 PM
juliodover11392
08-20-2011 02:22 PM
Quick Reply: Loss of top end power
