Rear wheel bearings
Rear wheel bearings
Out riding with some buddies today, I got some wobble when I got to around 140 and I backed off, It seemed strange though since I just replaced the front wheel and steering head bearings, But after checking it looks like the rear wheel bearings are shot as well. I have a 180-55 tire on , Does that fit on the stock rim? Or do I need to look for bearings a different wheel?
It does sound like rear wheel bearings. The 180 tyre is ok for the Mark 2 (89)and beyond but NOT for the Mark 1 (87/88).
Look for Naga_Thais' excellent 'How To' on rear wheel bearings.
Here it is - found it for you >>> https://cbrforum.com/forum/how-tos-8...r1000f-141525/ <<<
Cheers, SB
Cheers, SB
on
Know what - you may want to check your rear shock !
I had this happen on my `1990 at speed (90 +) on a trip - the rear wheel went into
what could be best described as severe oscillation - rear shock was screwed
and I was lucky not to get thrown at the time. I ended up stiffening up the sag
setting to the max stayed under 75 until I replaced the shock
Well I took a good look at the rear wheel wheel and just by looking at how bad the seals are are spinning the wheel on the axle I can see and feel that the bearing are bad, at one point in the rotation you can hear a bit of a metally crunchy grindy noise coming from the bearing. I sure hope the rear shock isn't bad the bike only has 15k on it, whats a good way to check though?
Okay so replacing the bearings today, they arnt nearly as bad as the front ones but still on there way out. I read Naga's writeup on the replacement and I don't understand how you get the Drive side bearing out in the first place, the axle guide is in the way. Could someone please give me a little more detail on this?
