Humming noise when cornering...
Hello
I have got the problem that I have been tracing for 3 years now. First things first... at some point she started to make noise when cornering or just when you leant the bike while riding in a waving fashion.
The sound resembled the one produced by a worn wheel bearing so they were the first thing I addressed. I bought new bearings for the front and the rear wheel including the rear sprocket bearing. To my surprise... no improvement....
It was in the first year.. I kept riding whereas at some point I inspected the tyres and I noticed the rear one cupping. It did stop my further research on the matter until now. However, after the discovery of the abused tyre I dismantled the rear swing arm, looked at the bearings there - they were sound, and looked at the rear shock - which had never caused me any trouble and there I replaced the bottom shock bushing (it didn't look good) and ordered new shock bolts from honda. I just thought it might have been the bushing that caused the cupping.. anyway... it was in the second year, I kept riding the old tyre...
And this year, and as there were still more things to address, I put her aside and my riding season came a bit later. I bought new tyres, new sprockets and a new chain. So it seems every bit of the drive train is in perfect order now....
I took her on the road and.... to hell... it humms when cornering, first I thought I would give the tyres some time to break in, but I did 300kms now and no improvement. I am starting to think, some engine component whines when the bike is leant?
I am out of ideas for now
PS. other than the noise she rides perfectly...
Two things come to mind..............
1 The front steering head bearings could be worn and causing noise when you corner....
2 Front shocks - is the oil level the same in both sides ?
Do you have any shuddering from the brakes when braking GENTLY - I did - had the bearings checked - they SAID the bearings were fine. THEY WEREN'T. Damned idiots nearly killed me when a bearing collapsed on me at high speed.
It's amazing how quickly you can destroy a tyre when the bearings are suspect............
1. Front head bearings are new and properly tightened, the bike is as stable as it can be...
2. The oil level is the equal, the front fork was inspected, the springs are in the upper service limit, no signs of any wear in the front suspension.
I don't get any shuddering, the bike is a pleasure to ride...
thanks
thanks
You know that I am a bit confused so I appreciate any odd idea because I checked all that was to be checked....
I don't know, I will take it for a ride with a go pro, perhaps I will be able to record it so you can hear a bit...
I have asked several people about the noise concluding it is a normal behaviour of this bike, but they say theirs OK... I can't remember having this noise just after buying but perhaps it was already there....
