How Many Gallons Before You Go on Res.?
This has bugged me for some time now. Honda says I have a 5.8 gallon tank inc. 0.9 gal res. I'll go on reserve, the engine starts to miss, sputter, between 176-186 miles and I fillup within 2-3 miles later. I'm only able to put 4.2-4.3 gallons in the tank. Do I really have 1.5 gallons left? I'm too chicken to find out the hard way. Every other Honda I've owned has been dead on with the fuel tank specs.
i am surprised that the lot of you actually drive with it in the 'on' position. i just always leave mine on 'reserve' all the time and just fill up when the gauge is getting low. i dont think ill ever care to try and run it out of gas.
however, im getting horrible mileage right now since im jetted slightly too rich with the pilots and i think my needle needs to come down a peg. im only getting 110 miles or so for 3.5 ish gallons.
Once on reserve - I have done 40 miles looking for a fuel station.
I find that having the reserve is nice for those days when you get out and lose all track of time and distance cos your enjoying the road.
I would rather cut out on reserve and have the extra in the tank - than cut out and have nothing left but a sodding big push to the gas station.
Clearly you've never had to push your bike for a mile or two, or leave it somewhere exposed. Your gauge must be a helluva lot more accurate than mine Ask me how I know this................
Bassman, the tank is supposed to take 22Litres, and mine did until I coated it which reduced it by about 500Ml. The reserve will give you around 60 Kilos or 35 miles.
I generally fill it up as soon as it hits reserve to avoid any sludge in the tank getting sucked into the carbs.
This I also found out the hard way...............
Hope this helps.
Math is fine, but sometimes on a windy road the fuel will slop around, and give you a false reading on how much you have left, so I wouldn't push it much beyond 40 miles to be safe - hell that's leaving you too little for my liking. I have evil memories of how heavy a pig these bikes are to push....................
The only other way to be sure, is to empty the tank completely and refill it from a jerrycan or something...................
