How to lift bike?
How to lift bike?
This may seem like a dumb question but....
I was wondering if anyone knew how to lift the 1000's? =)
I bought a lift from harbor freight http://www.harborfreight.com/1500-lb...lift-2792.html
And I realize most things I seen were a bit creative, putting blocks of wood under oil pan, lifting it up from ceiling (Sprock) lol, but has anyone used a lift like this? Does the exhaust have to come off or would it support the weight of the bike?
Thanks! =)
Thanks! =)
use this lifter if u don't to take off the exhaust.
http://2wheeldiscount.com/Biketek-mo...t--P83846.aspx
Yeah.... unfortunately paddock stands won't do anything for removing forks (although I have a set of cheap ones and haven't had any bending issues. Depends a lot on which ones you get, I guess)
Ryan, I'd suggest using a jack under the motor with a block of wood. I've done it several times. However, I'd also have the bike strapped, too, for extra security. You don't want that big girl going down.
on
+ 3 ........ block of wood ... I use a hoist sometimes only cuz it's there & the
previous owner worked for the power utility 20 ft joists / rafters , 12 foot garage doors
were factored into the garage for the on call utility trucks
You'll see with the front forks up and wheel off .....it can become a balancing act !
Strap it up or down from falling over ! no matter how you are lifting it
