have you seen a dropped 1991
Old 04-18-2010, 10:39 AM
willman's Avatar
Default have you seen a dropped 1991
I was looking around and found a 1991 cbr1000 for sale on craigslist and it was dropped 4" it really looked sick. what is all done to get this lowered? I know the rear is the challenge. Swapped swing arm?
Attached Thumbnails have you seen a dropped 1991-3kb3p83le5y15t35p1a3q5fa6d4e221951be3.jpg
Old 04-18-2010, 12:23 PM
hawkwind's Avatar
Don't know how they've done the rear . But you can drop the front by simply slipping the fork tubes through the yolks.
There have been previouse disscusions on how to drop the rear height , 'cos she's a heavy bike and for those with shorter legs it can be quite difficult to keep her upright if she starts to tip
So if you find out how to do it , post it up here!
Old 04-18-2010, 12:27 PM
Sprock's Avatar
Did the Dude have short legs or something ? If I did that I'd grind the pipes off in an
hour.
Old 04-18-2010, 03:10 PM
kilgoretrout's Avatar
Administrator - Retired
Well, that would pretty much ruin the handling, though.
Although sprock would never scrape those pipes, many would..... And with the soft front, I would think it would be bottoming out to the point where it was unsafe.
Old 04-18-2010, 03:55 PM
Bio248's Avatar
i dropped mine in the front about in inch by dropping the tubes. i was looking at dropping the rear, but looks like itll be a lot more work than i care to do.
will, ill work with you if you want to try and do something custom, but it seems like we are going to have to switch up more than just the link for the rear shock.
Old 04-18-2010, 04:29 PM
willman's Avatar
I need to find out what that swing arm I have is off of. I think thats what he was going to do is drop his.
Old 04-21-2010, 12:27 AM
Shadow's Avatar
"dog bones" won't work on this bike - something to do with the geometry of the suspension.
A shorter, stiffer spring might work. There is some history on this - look back through the "history: or send a PM to Dean0 - he's a whiz on suspension.
hour.
C'mon Sprockie - you had to fit Buell pegs to get them to touch down.....
A 1000F that low will smash the sump and fairings off on the first speed hump, and probably kill you. Fine if you only ride on airport runways, though
Old 04-21-2010, 07:58 AM
Sprock's Avatar
hour.
I just finished touching up the pipe shrouds .......... ya teasing son of a gun
Nothing to do with pegs never did put those on looked to low everything to do with a very sedentary winter routine have had to stiffen up the rear to take the added lbs / kg ........... so I've had to give up the Guinness
Dazed
09-18-2011 01:20 PM
bluej511
01-20-2008 10:56 AM
c0ldf1ame
04-24-2007 03:16 PM
okaw
03-13-2007 10:16 PM
sprout
02-10-2006 09:04 PM
Quick Reply: have you seen a dropped 1991
