Stick coils
Old 12-22-2012, 01:55 PM
boru's Avatar
Question Stick coils
hello all,
im thinking abut doing the stick coil conversion on my 1000f.
im watching a set from a cbr 600f 2001 on ebay.
so my question is would these be compatible?
thanks!
Old 12-25-2012, 06:46 AM
Dodgy Dave @ Drax's Avatar
I bought a set of a 2010 'Blade, and they were OK. You could ask the seller to check the impedance as per the Stick Coil thread - or you might have to buy and then check yourself. A thread with compatible bikes might be a good idea ! Best Wishes to All, cheers dave
Old 12-29-2012, 11:16 PM
wooferdog's Avatar
My research turned up a couple of things. The first four digits is the type of coil and they all seem to common in that respect. They second four digits seems to determine the application.
I used '07 CBR1000 coils with no problem. Others have used GSXR coils without issue. Suzuki used the same coils on all displacements, Honda did not.
My opinion is that the 600 coils MAY pose a height issue in regard to how much they clear the spark plug hole, but I cannot verify that. The 1000 coils clear with room to spare
What I do know, and others will vouch for this, is that the mod will be of benefit and will cure some problems. In my case it was cold start and the low end stumble.
Gone.
Good luck to you if you try the 600 coils. If they do the trick, please post back.
That would be valuable info
Sebastionbear1
04-20-2022 08:18 AM
Chad Brenno
06-23-2014 07:25 PM
Aman Lokhandwala
07-23-2012 11:12 AM
lordexpectation
12-19-2011 04:22 PM
Quick Reply: Stick coils
