f1 to f3 carb questions
Old 01-23-2011, 11:27 PM
patricksmithahhh's Avatar
Default f1 to f3 carb questions
will an f3 or f2 airbox fit f1 carbs on my 87 1000??? or could i swap the carbs all together
Old 01-24-2011, 03:14 AM
Shadow's Avatar
Carb throats & overall volume will be too small, you may get it to run but your fuel & air volume will be too low to run the bike properly.
You may end up with burnt valves or a hole in a piston.
If you need a set of 1000F carbs, I have a set off a Mk1/2
Old 01-24-2011, 05:00 AM
kiwi TK's Avatar
Crazy CBR Salvage Guy. RIP
The man obviously likes a challenge, if you have enough money you can stick a jet engine in a submarine.
Well done you for taking on that challenge; when you have finished I have a friend in Nigeria who needs to clear 20 000 000 through a foriegn account and is prepared to pay quite a handsome commission for an investor to go in with him. Keep it really quiet though,I don't want these other guys hearing about it
Old 01-24-2011, 09:13 AM
ranchome's Avatar
Or you can contact pfsnds to get a real set of 1000 carbs:
https://cbrforum.com/forum/cbr-1000f-hurricane-38/sad-sad-day-1988-1000f-rip-120399/
Old 01-24-2011, 02:14 PM
maybe i worded the question wrong what airbox will fit the carbs on my 1000f will only stock fit????? reason i ask is because there are a few f2/f3 airboxes available locally for cheap an why pay 80 for one off an 87 1000f when i can get one for 20 off a newer bike that may fit
Old 01-24-2011, 03:17 PM
shakey's Avatar
Why dont you fit K&N pod filters? They sound pretty damn good!
Old 01-24-2011, 03:46 PM
TimBucTwo's Avatar
What are you calling f3 or f4? Are you referring to the CBR600f3 or 4? Those will most likely not work due to spacing and frame configuration. If you are referring to the second and third generation CBR1000F that's a different issue.
Old 01-24-2011, 05:52 PM
shakey's Avatar
I think the question to be asked is " why do you want to swap the stock airbox" ???? Don't you have the original one? There must be one for sale on EBay or somewhere if you want to fit a stock one?
Quick Reply: f1 to f3 carb questions
