difficult starting for years
Old 04-18-2015, 07:39 AM
cbrpaul's Avatar
Default difficult starting for years
hi guys
a follow up on the last post to my difficult starting post
i went to the local honda guy who has known me and the bike on and off for years
in fact it was they that did the last intervention 4 yrs ago on the engine to change the stupid damper ( engine split) and its run only a little since
so the valves were set by them
he mentioned that the rocker gaps might be out of whack
i did check them and sure enought they had set several slightly too tight
i re set each one just a tad more open than spec and lo and behold it starts much better and idles more steady and pulls better at low revs
im next going to re set the air screws to see if i can get a less lumpy idle
moral of the story
it you want it done right do it yourself
cbrpaul
Old 04-18-2015, 03:10 PM
Sebastionbear1's Avatar
Too true Paul,
And well done for getting in there and getting it done.
Cheers, SB
Old 04-19-2015, 05:38 PM
Sprock's Avatar
Syncing the carbs will help smooth it out too also pop an extra washer on each carb needle to deal with the mid range stumble, best mod for under a buck !
Old 04-19-2015, 09:33 PM
DRam's Avatar
Very Honorable Most Senior Member :)
Default Well done.
Good on ya. And #1 on the carb sync.
Old 04-21-2015, 12:28 PM
cbrpaul's Avatar
will re do carbs this week
but after some drives now much better
twit honda dealers dont know what they are doing,,,
next is to find a new but not full price cbr1000fl stanchion in uk or eu
anyone got an idea??
Old 04-29-2015, 10:41 PM
Sprock's Avatar
Paul a shot of Lucas treatment can work wonders if the carbs have been sitting
Cocaine for carburetors
Old 05-03-2015, 02:27 PM
cbrpaul's Avatar
well guys as an update i've done some 100s of miles and its almost spot on
just going to re check the idle balance
moral of the story
if you have:
difficult starting
lumpy idle
cutting out at idle
poor acceeration and weak power
check the tappet clearances as they have closed up...or as in my case been badly set
by the mechanic
cheers
crbpaul
cbrpaul
05-09-2015 11:38 AM
Moussa Sleiman
08-24-2013 03:29 AM
adaśko
04-19-2010 05:31 PM
urandaman
07-13-2007 06:27 PM
SevenT6Vet
01-11-2007 10:50 AM
Quick Reply: difficult starting for years
