1987 CBR1000F handlebar weights ? Help!
Ok. I got this CBR (post accident) with handlebar end weights missing. I've tried aftermarket weights but the internal bar weights spin while tightening. I Get them tight as possible and ultimately lose them on the road.
Just picked up OEM bar end weights (correct listed parts). But looking at schematic online the bar ends are not listed under handlebar.
Can someone with the factory handlebar setup on this CBR enlighten me as to the exact layout or sequence from internal bar weight to bar end weight?
Also the length of flat head socket screw for the bar end weight if possible?
on
(Moved to it's own thread not a "How To" but a question)...........so
Inner bar weight should have locking clips that snap into slots on bar ends about
1/4 " from end - inner weight itself will be recessed about 1/4 "
Bar end screw/bolt is about 3 " as you tighten that screw it expands the rubber
grommet(s) on the inside - securing the entire inner bar weight and serving as
a vibration damper by isolating contact between the inside of the bar and the
inner weight metal shank
Sprock,
Thank you for moving my questions. Felt it was not in the right place but could not figure that out.
There appears to be some type of internal weights, and it seems that i am missing the locking clips and rubber grommets in both bars. Ordering those ASAP.
Really appreciate your help!
