600 F3 cutting off when going into gear
Old May 13, 2026 | 06:29 PM
tmat1729's Avatar
Default 600 F3 cutting off when going into gear
Hello, I have a 1996 CBR 600 F3 and every time I put on the biking gear, it cuts off. The kickstand light turns off when I pull it up, and it still cuts off, so I pulled off the clutch switch jumped the wires, and it started up in gear. So what do I need to do? I already replaced the clutch switch, and it still has the same problem, so I don’t know, and I believe the neutral switch is fine.
Old May 14, 2026 | 09:37 AM
I would suspect the side stand switch - it has 3 wires, a yellow and purple that goes to the indicator light and a green and white one that goes to the interlock circuit. Check the green and white wire for continuity (measure with a meter, not a “continuity checker”).
After that, the diodes in the interlock may be suspect.
AnthonyMGeorge
How-To: Mechanical
Aug 26, 2023 03:04 PM
Slydell19
Jul 15, 2010 03:50 AM
BTBTBT
Jul 11, 2010 02:46 PM
bwhittington00
Sep 4, 2007 05:43 PM
bwhittington00
Feb 17, 2005 11:25 AM
